VPN with 2811 set-up and Cisco VPN Client
Jan 22nd, 2009
  • Silver, 250 points or more
I am looking for the correct IOS to install on my 2811 so I can set up vpn groups, much like you would with a PIX for remote employees running the Cisco VPN Client software.
I have done this on a Pix 525 and 506e, but the company I work for today does not have a PIX, they employ a Juniper firewall and Juniper SSL device. I am creating a backdoor in the event the firewall dies and we cannot route internally remotely to gain cli access to bring the firewall back up. What I have to work with is a 2811 so any help would be appreciated.
Overall Rating: 5 (2 ratings)
kwillacey Thu, 01/22/2009 - 09:40
  • Bronze, 100 points or more
I think you need an Advanced Security or higher feature set for that.
pauloroque Thu, 01/22/2009 - 10:05
Do you just need the remote access vpn (RA VPN) feature or you realy need to be able to create vpn groups/user profiles?
For RA VPN, I think you can use any security or advanced feature set. For the exact IOS matching your needs you can use the Feature Navigator Tool (www.cisco.com/go/fn).
There search for IPSec feature and drill down on your platform, release e memory needs.
PRoque
Rick Morris Thu, 01/22/2009 - 10:12
I am basically trying to set up the same type of set-up on the 2811 that I would have done on the PIX525 by creating a vpn user group, assigning an address-pool and building an acl to allow access to the needed resources.
To mirror a replication of being on the network, with the ability to map drives, etc...
I have done this in a PIX just never on the router.
pauloroque Thu, 01/22/2009 - 10:40
Yes, it can be done. Use the Feature navigator as I said to find the correct IOS. A sample config follows.
PRoque
! 10.198.50.0/24 the inside protected network
! 10.199.x.x/24 the public address
! It will use IOS local user database for authentication
! The group to be used in the Cisco VPN Client is VPNCLIENT-GRP the key is 'grevpn'
aaa new-model
aaa authentication login LOCAL-AUTH local
aaa authorization network LOCAL-AUTHOR local
aaa session-id common
username proque password 0 mypass
crypto isakmp policy 5
encr aes 256
authentication pre-share
group 2
hash md5
crypto isakmp client configuration group VPNCLIENT-GRP
key grevpn
dns 10.198.50.6 10.198.50.7
domain youdomain.com.br
pool VPNCLIENT-POOL
acl VPNCLIENT-SPLIT-ACL
crypto ipsec transform-set ESP-AES-SHA-HMAC esp-aes esp-sha-hmac
crypto dynamic-map VPNCLIENT-DMAP 10
set transform-set ESP-AES-SHA-HMAC
reverse-route
crypto map VPNCLIENT-MAP client authentication list LOCAL-AUTH
crypto map VPNCLIENT-MAP isakmp authorization list LOCAL-AUTHOR
crypto map VPNCLIENT-MAP client configuration address respond
crypto map VPNCLIENT-MAP 10 ipsec-isakmp dynamic VPNCLIENT-DMAP
interface FastEthernet0/0
desc INSIDE NET
ip address 10.198.50.106 255.255.255.0
interface FastEthernet0/0.2
desc OUTSIDE NET
ip address 10.199.2.1 255.255.255.0
ip local pool VPNCLIENT-POOL 10.198.50.129 10.198.50.140
ip access-list extended VPNCLIENT-SPLIT-ACL
permit ip 10.198.50.0 0.0.0.255 any
Rick Morris Thu, 01/22/2009 - 10:45
Thank you this is what I was looking for.
