catalyst 4510's
Answered Question
Jan 22nd, 2009
Has anyone used a 4510 as an access switch, i have inherited a system doing just that, and to be honest the cabling is a logistical nightmare. I've got two supervisors, one 48 port SFP card, and seven 48 port RJ45 cards. This is causing a huge headache just because of the quantity of cabling in the rack. Anyone else using a 4510 for this type of role?
Correct Answer by Mark Yeates about 8 years 6 months ago
I too have used a 4510 as an access switch loaded down with 48 port blades. It is a challenge to manage that many cables. If done right the first time and properly maintain the cables you will be fine.
Mark
Correct Answer by Jon Marshall about 8 years 6 months ago
Joe
As Victor quite rightly says this is quite common. In the last place i worked we deployed 4510R's into the access-layer for a VOIP deployment. I don't recall any major issues with the cabling - yes there is a lot of it but with structured cabling it is easily managebale.
Jon
Correct Answer by lamav about 8 years 6 months ago
Joe:
There are probably a million networks out there using a 4510 for this role. So what is it you need help with?
Victor
Overall Rating: 5 (3 ratings)
Correct Answer
lamav Thu, 01/22/2009 - 10:03
  • Blue, 1500 points or more
Joe:
Victor
Correct Answer
Jon Marshall Thu, 01/22/2009 - 10:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Joe
Jon
Correct Answer
Mark Yeates Thu, 01/22/2009 - 10:22
  • Gold, 750 points or more
Mark
joereid44 Fri, 01/23/2009 - 01:29
Thanks guys. I was looking to see if there were alternatives that could be employed, but it sounds like this is the best solution (as long as it is intially implemented correctly)and I can keep the cabling uder control.
