WLC Templetes and Nortel VPN
Jan 22nd, 2009
I have several controllers at remote sites that I cannot push WLAN templates to. I am running Contivity routers. Whenever I attempt to send the template it fails but does not give me a reason. Does anyone the ports the WLC using to send templates. The WLC was able to discover them fine. It just seems to be an issue of sending the templates.
sschmidt Thu, 01/22/2009 - 14:51
  • Cisco Employee,
Can you do a "save config to flash" to the same controllers successfully? If you then do a refresh config from controllers" with delete is that successful?
If the save is successful and the refresh is not I'd say and issue with mtu over the vpn maybe. Check to to see how many varbinds you are sending under Administration > Settings > SNMP Settings. If it is greater than 50 change to 50 and save then try the test again.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
