How to close session in call manger V 4.1
Jan 22nd, 2009
I have call manger V 4.1 and I am administrator for this call manger and I have 2 operators if I need to close operators session how I can make it I don't need to remove operators account but I need to close sessions
Jaime Valencia Thu, 01/22/2009 - 11:04
what do you mean?? you have AC and want to logout users?? or do you mean MLA?? what???
java
if this helps, please rate
ahmed_saleh Thu, 01/22/2009 - 11:10
I think that an external user access the CCM admin from web and I want to close this session and see the logs of that user
Jaime Valencia Thu, 01/22/2009 - 11:13
1st of all, is your server accesible thru the web????
2nd, using MLA??? if so simply do not grant modify permissions,
3rd simply change the pwd if not using MLA
if you expect to get change logs there are none, only MLA if using it and if enabled (only show logins)
java
Jaime Valencia Thu, 01/22/2009 - 12:22
if using MLA and only if enabled the logs, look at the MLA logs as i already mentioned
if not then there's nothing
java
