Route Pattern Block Reason
Answered Question
Jan 22nd, 2009
I am trying to find documentation on the drop down box for block reason on a route pattern, does this show in logs somewhere because it doesn't seem to show on the phone when the call is blocked.
Thanks.
Correct Answer by Jaime Valencia about 8 years 6 months ago
only shows on CUCM trace
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 01/22/2009 - 12:08
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Jonathan Schulenberg Fri, 01/23/2009 - 03:48
  • Cisco Designated VIP,
    2017 IP Telephony
and on the phone's display to tell the user why their call was not routed.
seaman0555 Fri, 01/23/2009 - 10:19
I have not seen it show up on the phone, you just get a fast busy.
Jaime Valencia Fri, 01/23/2009 - 12:01
  • Cisco Employee,
  • Hall of Fame,
    2011
and that's the right behavior, users do not get any kind of message or notification the call cannot be made due to restrictions.
the moment you match a pattern with block this pattern there is no further action other than sending the phone reorder.
java
