CISCO 5505 ASA Lost userid/password
Answered Question
Jan 22nd, 2009
a. Anyway to recover userid/password on CISCO 5505 ASA? The original network person quit suddenly.
b. There is a 'reset' button - haven't tried it as I do not want to lose the settings. Will pressing this cause loss of settings?
Thanks..Any response will be great..-Vasan
Correct Answer by Collin Clark about 7 years 9 months ago
Follow the steps from this link and you should be good to go.
Hope that helps.
Overall Rating: 5 (1 ratings)
vvaradarajan Tue, 02/17/2009 - 08:09
Great Sir! Thanks..It worked and did not disturb the original configuration..
Richard Burts Tue, 02/17/2009 - 10:07
If Collin has provided a solution and your problem is resolved it would be appropriate to use the rating system, to click the check mark indicating that your problem is resolved, and perhaps to assign a rating to Collin's response.
