Jon Marshall Thu, 01/22/2009 - 12:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
A vlan is a layer broadcast domain. So two devices in the same vlan can see each other without needing the presence of a router.
If you have 2 vlans and a device in each vlan then you need to route between the 2 vlans and for this you either need a router or a L3 switch.
Jon
lamav Thu, 01/22/2009 - 13:16
  • Blue, 1500 points or more
Just to add a bit to Jon's post, you can have more than one subnet in a vlan.
Take vlan 10.
interface vlan 10
ip address 10.10.0.0 255.255.254.0
The subnets for vlan 10 are:
10.10.0.0/24
10.10.1.0/24
A device with address 10.10.0.5 can reach 10.10.1.5 without the need of a router because they are in the same Layer 2 broadcast domain - in other words, in the same vlan.
engbandar Thu, 01/22/2009 - 15:35
+if i want stop device see etch other what can do to stop this+
