Can't see or format ata 64mb flash
Answered Question
Jan 22nd, 2009
We are trying to convert a sup2/msfc2 from hybrid to native. However, we are getting trouble trying to format the 64mb card which we need because it's big enough to hold the ios. I'm pretty sure this flash was formatted on a native ios. Note that we are able to format and view a 24mb flash.
This is what we have:
Console> (enable) show version
WS-C6509 Software, Version NmpSW: 8.5(1)
Copyright (c) 1995-2005 by Cisco Systems
NMP S/W compiled on Oct 22 2005, 11:11:35
System Bootstrap Version: 7.1(1)
System Boot Image File is 'bootflash:cat6000-sup2k8.8-5-1.bin'
System Configuration register is 0x2102
Hardware Version: 2.0 Model: WS-C6509 Serial #: SCA045101QH
PS1 Module: WS-CAC-1300W Serial #: SON04330275
PS2 Module: WS-CAC-1300W Serial #: SNI06061830
Mod Port Model Serial # Versions
1 2 WS-X6K-S2U-MSFC2 SAD054406VZ Hw : 3.15
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 8.5(1)
Sw1: 8.5(1)
This is the error:
Console> (enable) dir slot0:
error = -24
Open device slot0 failed (bad device info block)
Console> (enable) format slot0:
All sectors will be erased, proceed (y/n) [n]? y
Enter volume id (up to 31 characters):
error = -85
Format device slot0 failed (can not find flash algorithm)
Console> (enable)
Correct Answer by yunuserduran about 7 years 12 months ago
try format disk0:
Overall Rating: 4 (1 ratings)
bedevere.curry Fri, 01/23/2009 - 05:55
Maybe if we can find a native IOS that's less then 24 mb so we can use that to convert from hybrid to native. After that, we can then possibly format the 64mb card and upgrade the IOS? Does anyone know the smallest native IOS we can use?
