Cannot reinstall Cisco Call Connector and have it connect to server
Jan 22nd, 2009
I recently had to reinstall windows xp on my desktop so I reinstalled Cisco Call Connector and no matter what I do it will not connect to the UCC Server. It did work before I redid my Windows installation. I have even try to unstall it along with the TAPI piece and everything tests out ok when you have to do the test connection in the install of Cisco-CUCME-TSP.
Any ideas ?
jbayuka Thu, 01/29/2009 - 06:43
  • Bronze, 100 points or more
post the following:
Set up details for the UCC including all version info
OS types being used
CME version, router IOS version
jlauner99 Thu, 01/29/2009 - 07:06
I resolved this issue. What was happening is when I uninstalled the Call Connector Client it did not remove everything from the registry. So I used a registry cleaner after the uninstall and then it reinstalled and worked just fine.
