Unable to make direct outside calls
Jan 22nd, 2009
I am setting up a new office with VOIP. They are able to recieve calls fine, but whenever I try to make an outside call it tells me the call cannot be completed. Here is a the kicker; I can make and outside call if I use a speed dial set up on a tranlsation pattern ie. #24. Any help would be appreciated.
Chris Deren Thu, 01/22/2009 - 13:54
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
This seems like a Calling Search Space/PT issue.
Is the route pattern used for outside calling in a parition that is reachable from the CSS applied to the phone?
How quickly do you hear this message, after all the digits are dialed or sooner?
Are the calls that work via speed dial origniating from the desired GW?
Have you tried analyzing the call flow via Dialed Number Analyzer? What does that show?
HTH,
Chris
Nicholas Matthews Thu, 01/22/2009 - 14:58
  • Red, 2250 points or more
It sounds like you may be using an MGCP PRI.
'debug isdn q931' on your PRI and see if the National/Unknown/ISDN numbering/plan types change when you speed dial and when you dial normally. There have been cases where the speed dial changes this, I believe.
hth,
nick
