ACSv4.2 appliance
Answered Question
Jan 22nd, 2009
Hi - I have the following questions:
1.- Where can I find out if there are updates (patches) for the version I'm running? I've tried searching Cisco and google and I'm not able to find a link.
2.- How do I find out the version of java the appliance is using? and can this java version be changed?
Thank you very much for your help!!!
Cheers!
Correct Answer by Jagdeep Gambhir about 8 years 3 months ago
1). Here is the link to download the patch. You need to use your CCO id.
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
2). Java is used on the system from where you access appliance and not on appliance it self.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
