CUCM 6.1 - Attendant Console speed dials and other lists
Answered Question
Jan 22nd, 2009
Where does the data for speed dials and other lists that the AC user personalizes get stored?
Correct Answer by mattcalderon about 8 years 3 months ago
The txt file is stored here.
C:\Program Files\Cisco\Unified Communications Manager Attendant Console\userlists for the corp directory.
You can actually export the speed dials by going to File-->Export Speed Dial
Edit: Just found the speed dial location its here:
C:\Program Files\Cisco\Unified Communications Manager Attendant Console\data\
This houses a globalsetting.xml file and then each AC user that has logged on.
Matt
Matt
Overall Rating: 5 (1 ratings)
Correct Answer
mattcalderon Thu, 01/22/2009 - 15:05
  • Silver, 250 points or more
Matt
Matt
phretbored Thu, 01/22/2009 - 15:53
Matt,
Right on.
Now that I am looking at AC again after a long while I remember seeing the data folder before.
Also the export/import speed dial features are just what I needed.
Thanks!
