Client Matter Codes
Jan 22nd, 2009
I understand how outbound calls work with CMCs. Can someone give me an explination on how to put a client matter code on inbound calls? Thank you in advance.
Erik
Overall Rating: 5 (1 ratings)
Chris Deren Thu, 01/22/2009 - 17:04
You cannot, CMC are strictly for outbound as they are only applied to route patterns.
Sorry...
HTH,
Chris
erikjustinlee Thu, 01/22/2009 - 17:27
So the way to add a CMC would be to do like a screen pop or something custom? I know there are programs out there, but they are all quite expensive.
Erik
Jaime Valencia Thu, 01/22/2009 - 17:35
CUCM has no way to do this, even call blocking is done on the H323 GW not on CUCM.
the only ways i can think of doing this are creating custom scripting for the H323 (if using, if MGCP you'll have to switch), the other way would be using UCCX/UCCE but then again, you need to create the custom script
java
if this helps, please rate
