RTCP Sender Reports Feature
Jan 22nd, 2009
I am using Cisco 7940/60 ip phones, curious to know if they support RTCP Sender Reports Feature.
Also if i can get the phones which supports and which doesn't.
Thanks in advance.
Jaime Valencia Thu, 01/22/2009 - 21:14
  • Cisco Employee,
  • Hall of Fame,
    2011
if you go to CCO, look for
RTCP Sender Reports
and then on left side choose
Cisco Unified IP Phones 7900 Series (62)
you'll get all of them, please try searching CCO as all the info is already there if you take a couple of minutes and search
the phones you mention do not support it
java
if this helps, please rate
Nicholas Matthews Thu, 01/22/2009 - 21:24
  • Red, 2250 points or more
The 7940/60 phones do not support RTCP. It's a matter of available memory in the phones, and they just didn't have enough memory to program in the RTCP code. They use their own methods to calculate. In some call flows, the CUCM or CME will often generate the RTCP for the phones.
Hope this clarifies a bit.
-nick
