DMVPN with digital ceritificates and Hub acts as CA server
Answered Question
Jan 22nd, 2009
Hello guys,
is there anyway to configure DMVPN with digital certificates and make the Hub router to act as a Certificate Authority server?
Correct Answer by Ivan Martinon about 8 years 3 months ago
Yes, you can do that, go ahead and configure your Hub router with the normal DMVPN setup so that it becomes the HUB. After you have done that follow the link below to add PKI server features:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gt_ioscs.html
And to enroll the spokes to the hub use this link:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080210cdc.shtml
Remember that regardless of the Hub router being the CA authority, you need to enroll it to himself to allow IKE PKI authentication.
Overall Rating: 5 (1 ratings)
Correct Answer
Ivan Martinon Fri, 01/23/2009 - 09:47
  • Cisco Employee,
