IPCC Express redirect feature
Jan 23rd, 2009
Hi all,
is there the possibility to redirect the call if the call presented to IPCC is not answered by agents (not in queue)!!!
Sometime, agents do not answer to calls, and the call loop continuosly between agents that are in ready state but do not answer. In this situation, can i redirect this call to another destination after 60 seconds (for example)?
Thanks in advanced
Diego
mikram Fri, 01/23/2009 - 03:05
  • Bronze, 100 points or more
Hi Diego,
You could redirect call after 60 seconds to agent in other CSQ if he/she is logged in or send it to voice mail asking caller if they want to leave message press 1 .
d.rocco Fri, 01/23/2009 - 03:26
Yes of course, How can do it?
What is the variable that i need to use to implement this?
Do you have an example?
Diego
Jonathan Schulenberg Fri, 01/23/2009 - 03:39
  • Cisco Designated VIP,
    2017 IP Telephony
First of all, the call should not be "looping continuously amongst agents in the ready state who do not answer." The default behavior is for an agent to be placed in the Not Ready state if they fail to answer a call presented to them. You can check the Service Parameters page to confirm this is setup correctly.
Once the caller is sitting within the Queued branch of the Select Resource step, you can do any of the things mentioned:
1) Offer voicemail: Add a menu step with a Dequeue and Call Redirect step within the selected branch. Within the success branch of the Call Redirect, add a Set Contact Info = handled.
2) Queue to an additional CSQ: Add another Select Resource step. Within the Connected branch of the second/nested Select Resource step, add a Dequeue step for the first CSQ.
3) Transfer to another off-net destination. Add a Dequeue and Call Redirect step. Within the Success branch of the call redirect, add a Set Contact Info = handled.
