number of DSPs needed for 5 ISDN PRI interfaces on 2811 platform
Answered Question
Jan 23rd, 2009
Hi all!
I have one Cisco 2811 router as a VoIP gateway between Telco and my CCM.
Currently, there's one ISDN PRI over 1-port T1/E1 Multiflex Voice/WAN Interface Card. There is PVDM2-32 module also and everything works fine so far.
Now I need to connect to CCM the four additional ISDN PRI interfaces from telco.
My question is can I achieve it on this router with:
1. adding two 2-port T1/E1 Multiflex Voice/WAN Interface Cards and
2. upgrading to two modules PVDM2-64 in total?
or
maybe should I go with a new router (which is less desired solution)?
In other words, would it be a problem to have 5 PRI interfaces with 2x PVDM2-64 modules in total on 2811 platform. Would it be enough?
TIA
Zoran Milenkovic
Correct Answer by paolo bevilacqua about 8 years 5 months ago
I realized my mistake and corrected my reply.
The point is that if you don't have enough DSP, you cannot configure the PRI interface at all, so as I said either get a bigger router, or install an NM-HDV2-xx.
Hi, you cannot use only PVDM2 on 2811 for 5 x E1, because the the 2811 has only two PVDM2 slots, and you need 3.
5 x 30 = 150 channels, 2 PVDM2-64 makes only 128 channels.
So, eithjer replace the router with abigger one, or use the PVDM2 on borad in conjuction with an NM-HDV-xxx.
If you have service contract, you can use the online DSP calculator for this kind of things.
Overall Rating: 5 (2 ratings)
Correct Answer
paolo bevilacqua Fri, 01/23/2009 - 03:16
  • Hall of Fame,
    Founding Member
mizoran78 Fri, 01/23/2009 - 03:30
Thanks for answering but 2811 has only two PVDM2 slots :( That means that I can have two PVDM2-64 modules at maximum!
So if I have 5 ISDN PRI interfaces, I am wondering would it be enough?
Can we assume those two PVDM2-64 modules as a kind of 80% coverage of ISDN interfaces by DSP resources or not? Somebody with experience in similar scenario?
Zoran Milenkovic
Correct Answer
paolo bevilacqua Fri, 01/23/2009 - 03:54
  • Hall of Fame,
    Founding Member
mizoran78 Fri, 01/23/2009 - 04:03
That's exactly what I wanted to know!
Thanks!
Zoran Milenkovic
paolo bevilacqua Fri, 01/23/2009 - 04:21
  • Hall of Fame,
    Founding Member
Thank you for the nice rating and good luck!
