joereid44 Fri, 01/23/2009 - 02:18
If this is the 500 express model, then yes, you can create vlans.
Use a web browser to connect to the switch and the menu options are on the left, including vlans.
prit.gupta Fri, 01/23/2009 - 02:32
Thanks for reply. We have Two Switch (WSC 500 Series 24 TT). Both are connected.We want to Create Inter VLAN and also want to access both VLAN from each other.
We have Two Server we want to access this server from both VLAN. Please provide your assistance on the same. How we should do this?
joereid44 Fri, 01/23/2009 - 03:10
If you need intervlan connectivity, then you'll need a router or a L3 switch. Only they can perform intervlan connectivity.
prit.gupta Fri, 01/23/2009 - 03:22
Thanks Again.
Ok Fine.
I am also Planning to Install the FortiGate FG 50 B model Firewall.
Will Firewall help me to setup the Inter vlan by using the Firewall features/Software?
prit.gupta Fri, 01/23/2009 - 02:48
