CUCM 7.0 recording capabilities
Answered Question
Hi all,
What are the possibilies offred by CUCM 7.0 to allow end users (or special users) to record theirs communications. There is no Contact Center component in the infrastructure.
If Call Recording is not possible natively, which components should be added to have it possible.
Thanks in adavance.
Correct Answer by Jaime Valencia about 8 years 6 months ago
CUCM does not provide call recording
you can use one of these
Witness
www.witness.com
Nice
www.nice.com
IPcelerate
www.ipcelerate.com
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 01/23/2009 - 05:09
  • Cisco Employee,
  • Hall of Fame,
    2011
UCC can also work for monitoring and recording
java
Frederick Nielsen Fri, 01/23/2009 - 08:48
  • Bronze, 100 points or more
You may also want to look into the "live record" feature in Unity if you have it available in the environment. It is not automatic, but may fit your needs as well.
jillmajors Mon, 01/26/2009 - 12:08
There are quite a few third party call recording vendors that can help you with your issue, including Verint/Witness and IPCelerate (as previously mentioned in this thread).
Telrex also offers call recording solutions that can fit your needs; see http://www.telrex.com/cisco_call_recording.htm for additional informaiton.
