compression header ip rtp
Answered Question
Jan 23rd, 2009
I tryed to configure rtp header compression in the policy attached to FastEthernet and failed-
Col(config-pmap-c)#compression header ip rtp
%FastEthernet0/0 does not support IP header-compression
Why it is so?
Correct Answer by paolo bevilacqua about 8 years 5 months ago
With native encapsulation, nothing.
In theory you could run a VPN between routers, and run compressed IPsec on it to gain LZH compression (cRTP doesn't work with ipsec), but it seems an overkill.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Fri, 01/23/2009 - 03:29
  • Hall of Fame,
    Founding Member
Because cRTP is not supported on ethernet - there is no standard for that.
rmv72 Fri, 01/23/2009 - 04:00
than what i can use to compress rtp traffic on the Ethernet links?
Correct Answer
paolo bevilacqua Fri, 01/23/2009 - 04:11
  • Hall of Fame,
    Founding Member
