CUPC VM via IMAP unknown number
Jan 23rd, 2009
cupc 7.x, cups 7.x when a user that is not cup enabled leves a message and we retrieve via CUPC client we get to see the number that called so we can ring it back . However if its a cupc enabled caller then we see 'unknown number' when retrieving via IMAP....cheers, Jeff
htluo Fri, 01/23/2009 - 07:15
  • Red, 2250 points or more
you said "when a user that is not cup enabled...". I'm assuming you know where to enable it? :)
Michael
jeff.singh_2 Fri, 01/23/2009 - 07:27
Michael,
sorry did'nt explain myself clearly. We know where to CUP enable users.
The issue is that a non cup registered user leaves a VM messsage that is retrieved by the CUPC using IMAP shows the number of the caller. However when a CUP enabled user leaves a message and we retrieve via IMAP on CUPC we only get 'unknown number' in the number field.(no problems retrieving the message)...TIA, Jeff
htluo Fri, 01/23/2009 - 07:48
Oops...I thought it was the other way around. :(
Just for testing purpose, can you do this?
1) Ask a CUP user (user A) leave a voicemail for another CUP user (user B).
2) Ask user B retrieve the VM from CUPC. It should show the number as 'unknown' if I understood it right.
3) Make user A a non-CUP users (on CUCM > System > Licensing > Capability Assigments).
4) Repeat step 1 & 2 again. See if there's any difference?
Thanks!
Michael
jeff.singh_2 Mon, 01/26/2009 - 01:06
We have reproduced using the above steps. The only way we can make it work correctly if we make display name for Unity different to the name as it appears in AD i.e if the AD name for the user is User1 and its Unity display name is User1 then we will not get the number displayed if a message is left from a CUPC user. If however we change the display name in Unity to User 1 (notice the space) then it works fine. As soon as the display names match it causes a problem. (we can change the display name in Unity but customer wants it the same).
htluo Mon, 01/26/2009 - 06:42
Have you opened a TAC case for this? This doesn't make sense to me.
If you could, open case between 12:45pm and 3:15pm CST and ask for "Michael Luo".
Thanks!
Michael
jeff.singh_2 Mon, 01/26/2009 - 07:04
Thanks Michael, I will get an on site colleague to get some more info and raise a case...J
