Radius Accounting configuration on the WiSM
Jan 23rd, 2009
Can anyone clarify for me what the setting 'Network User' on the WiSM Radius Accounting configuration page actually means?
This is what the Help file says:
Network User - Enable or disable network user authentication. If this option is enabled, this entry is considered as the RADIUS authenticating server for the network user.
But that doesn't help me much. Radius Accounting is working without that setting turned on- what does checking the 'Network User' box add/change?
thanks,
Lynne
Stephen Rodriguez Mon, 01/26/2009 - 12:41
  • Purple, 4500 points or more
that Network User box, allows the controller to use that AAA server globally. Best practice is to not check that box, and specify the AAA server in the WLAN that needs it.
HTH,
Steve
lynne.meeks Mon, 01/26/2009 - 12:53
Steve,
Thank you.
That's exactly what I needed to know.
Lynne
