01-23-2009 06:50 AM - edited 03-15-2019 03:43 PM
I want to prefix 91 for all inbound PSTN calls so users can redial without having to edit. We currently have the telco send us 4 digits and then we have a translation rule that prefixes the call with a two digit site identifier (i.e we have 6 digit internal dialing). How can I create a rule that accomplishes both?
voice translation-rule 1
rule 1 /^\(....\)$/ /31\1/
voice translation-profile InboundVoice
translate called 1
Solved! Go to Solution.
01-23-2009 06:59 AM
First of all, are you using CUCM or CME? Second, the two-digit site identifier only applies to the called number, correct?
If you want to/need to do this within the IOS on the VG, you can create a second translation rule and apply it to the calling number. Something like this:
voice translation-rule 2
rule 1 /^/ /91/
translate called 1
translate calling 2
01-23-2009 06:59 AM
rule 1 /^/ /91/
translate called 1
translate calling 2
01-23-2009 07:11 AM
Thanks...that works!
