VPN Access Reporting.
Jan 23rd, 2009
<br />
<br />I am trying to pull a report of all users that have accessed out vpn through our ASA 5540 firewall. Is there a way to generate or get a report of that?
<br />
<br />Thanks Richie
eddie.mitchell@... Fri, 01/30/2009 - 14:38
  • Silver, 250 points or more
Do you currently have a log management solution in place?
If not, there are several tools available to create reports based on ASA firewall logs. The Firegen product can create reports based on Cisco ASA syslog messages which will show VPN usage:
http://www.eventid.net/firegen/
Hope this helps.
