ACS 4.2 update a network device shared secret key
Jan 23rd, 2009
We were using csv files (accountActions format)to import multiple network devices into ACS. Someone put in the wrong shared secret in the import file. I am trying to update the database using the 224 action code. I get a sucessful sync with 300+ transactions but the key does not change. Am I doing something wrong?
didyap Fri, 01/30/2009 - 15:32
  • Silver, 250 points or more
Make sure that Direction on the remote server is set to Incoming and Outgoing or Incoming, and that the direction on the authentition forwarding server is set to Incoming and Outgoing or Outgoing.
Shared secret (key) matches the shared secret of one or both ACSs.
Character string and delimiter match the stripping information configured in the Proxy Distribution table, and the position is set correctly to Prefix or Suffix.
