ACS compatibility between versions 3.3.3 and 3.3.4
Jan 23rd, 2009
Hello, can I use in ACS 3.3.3 configuration backup file which has been created in ACS 3.3.4 ?
Thank you
mchin345 Thu, 01/29/2009 - 06:48
I think you can't use same configuration file. Certain versions of Cisco Secure Access Control Server (ACS) for Windows and the Cisco Secure ACS Solution Engine (here after both referred to as purely Cisco Secure ACS) are affected by multiple vulnerabilities that cause specific Cisco Secure services to crash. Two of the vulnerabilities may permit arbitrary code execution after exploitation of the specified vulnerability. So please make sure about it.
