Callmanagers different HDD Firmware
Jan 23rd, 2009
CCMPUB01 HDD Firmware versions Kind of Drive
Port 2 : SCSI ID 0, Internal HPB2 SCSI
Port 2 : SCSI ID 1, Internal HPB5 SCSI
Port 2 : SCSI ID 2, Internal HPB5 SCSI
Port 2 : SCSI ID 3, Internal HPB2 SCSI
CCMSUB01
Port 2 : SCSI ID 0, Internal HPB5 SCSI
Port 2 : SCSI ID 1, Internal HPB1 SCSI
Port 2 : SCSI ID 2, Internal HPB2 SCSI
CCMSUB02
Port 2 : SCSI ID 0, Internal HPB9 SCSI
Port 2 : SCSI ID 1, Internal HPB9 SCSI
CCMSUB03
Port 2 : SCSI ID 0, Internal HPD5 SAS
Port 2 : SCSI ID 1, Internal HPD5 SAS
Port 2 : SCSI ID 2, Internal HPD5 SAS
Port 2 : SCSI ID 3, Internal HPD5 SAS
CCMSUB04
I have 5 servers. 3/5 have different HDD firmware and was wondering if this is safe to run with old and new hdd firmware.Can you pls provide me this information.
David Hailey Mon, 01/26/2009 - 19:31
  • Purple, 4500 points or more
The official answer that you would receive from Cisco, HP, and/or IBM is that you should run consistent firmware across all systems. In addition, they also recommend that you run the same speed of drive at least on a server level - i.e., all drives are 10k or 15k - not mixed and match.
Unofficially, at a previous company I've been at we had 8 CCM clusters one of which was a fully loaded cluster. Over the years, we ended up with mixed firmware and mixed drive speeds and there was no clear indication that it specifically caused any issues.
