01-23-2009 09:51 AM - edited 03-06-2019 03:37 AM
I'm baffled why the url
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfindp2.html#wp1022511
shows network 10.134.0.0 for instance
as a result of the command
Router# show ip route 128.0.0.0 128.0.0.0 longer-prefixes
01-23-2009 10:31 AM
the text says
The following is sample output using the longer-prefixes keyword. When the longer-prefixes keyword is included, the address and mask pair becomes the prefix, and any address that matches that prefix is displayed. Therefore, multiple addresses are displayed.
In the following example, the logical AND operation is performed on the source address 128.0.0.0 and the mask 128.0.0.0, resulting in 128.0.0.0. Each destination in the routing table is also logically ANDed with the mask and compared to that result of 128.0.0.0. Any destinations that fall into that range are displayed in the output.
I tried on my router and actually it shows prefixes despite the first byte value
if I use 255.255.255.0 255.255.255.0 I see nothing for example.
if I use 64.0.0.0 64.0.0.0 I see some routes only a few in comparison with 128.0.0.0 128.0.0.0
This command in this way doesn't look like immediate.
Hope to help
Giuseppe
01-23-2009 02:20 PM
thanks for reply Giuseppe
I can understand the command in circumstances say where you have a number of routes of longer prefixes to the network and mask listed
e.g.
sh ip ro 172.30.80.0 255.255.240.0 lo giving say
172.30.80.0/24
172.30.81.0/24
172.30.88.16/28
However I can't see how 10.134.0.0 results from sh ip ro 120.0.0.0 128.0.0.0 lo
It is also possible to use non-contiguous masks such as
sh ip ro 10.0.0.0 12.0.0.0 lo
and get routes listed
Can you make any sense of it?
