01-23-2009 11:18 AM - edited 07-03-2021 05:03 PM
I've blown half a day looking for a rudimentary config example for a point to multipoint bridging design. Would like an example config for the 1310 root and 1310 non-root(a) and non-root(b). I hate to spend days developing this when I can stand on the shoulders of those who've died doing what they love before I came along. Any help AND url links would be appreciated.
01-27-2009 08:32 AM
Here are configs for the root and non-root. The only difference is setting the root to root and choosing a channel. The non-root do not get to choose a channel, only set them to non-root.
Here is the root config:
dot11 ssid Wireless
authentication open
authentication key-management wpa
infrastructure-ssid
wpa-psk ascii whateverkeyyouwant
username admin privilege 15 password setyourpasswordhere
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
broadcast-key change 300
ssid Wireless
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
cca 75
concatenation
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.100.8.35 255.255.255.0
no ip route-cache
ip default-gateway 10.100.18.1
Here is the non-root config, it is the same for all remotes, you only need to change the IP address and host names.
hostname Remote
enable password setyourpassword
ip subnet-zero
no aaa new-model
dot11 ssid Wireless
authentication open
infrastructure-ssid
bridge irb
no ip address
no ip route-cache
ssid Wireless
station-role non-root wireless-clients
cca 75
concatenation
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.100.8.36 255.255.255.0
no ip route-cache
ip default-gateway 10.100.8.1
02-04-2009 05:16 AM
Thanks. Didn't know if it would require different bridge groups for each root-to-nonroot connection. This looks simple enough. I noticed you made the station role of the non-root "wireless clients" as well. Is this feature to offer ap connectivity to clients behind the non-root? Thanks again.
