ACS + VPN
I have VPN set up on one of our ASA, the ACS server handles all the policies and the users are mapped to groups from Active Directory.
Now I have another ASA which will also be used to VPN into, however I need to assign different policies to people when they VPN into this device (different access hours, IP pool, etc)...the problem is some users could VPN into either device so I need to be sure the proper group is assigned to them depending on which device they're VPNing into...is that possible??
smahbub Thu, 01/29/2009 - 15:45
  • Silver, 250 points or more
You can add the same user in this group also. Then they can easily VPN into either ASA device. Those who need to access both the ASA.
