4.3/AD integration
Answered Question
Jan 23rd, 2009
I have a customer with the AD plugin installed. All my previous 4.x systems have been DCD based. The Publisher is in a workgroup and not the domain.
If I install a patch, do I have to re-install the plugin afterwards?
Would I need to remove it before running the patch?
Also what about moving from 4.3(1) to 4.3(2), same issues?
Any gotchas I should be aware of?
Many thanks.
Correct Answer by gogasca about 8 years 2 months ago
For everytime you upgrade, YES, you need to re-run the AD plugin in case we make some changes to the libraries or schema.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dir_plugin/plug431.html#wp62839
Overall Rating: 3.8 (3 ratings)
Jaime Valencia Fri, 01/23/2009 - 12:39
  • Cisco Employee,
  • Hall of Fame,
    2011
no, unless you make changes to the AD and need to choose different OUs other than the ones already configured there is nothing to look out for or need to rerun the plugin
java
if this helps, please rate
billybjo1 Sun, 01/25/2009 - 12:29
Ok thanks for the replies.
I've compared the "component version" on this system of the AD plugin and that of another already upgraded system and they show the same version for that item. Would that indicate there is no need to re-run the plugin, or does that not really indicate of there have been any schema changes.
gogasca Sun, 01/25/2009 - 15:45
  • Green, 3000 points or more
You should be good then as long as everything is functioning normally.
