UCCX5.0.1 - password when agent login
Jan 23rd, 2009
-CUCM6.0.1, integrate to AD2003
1. I'm able to login the agent with the above credential
2. chagned the AD password to Password2 but still I able to login the agent with 'Password1' or 'Password2'. Not able to login if I enter other than one of two
3. change back the AD password to 'Password1' and the agent able to login with both
4. when I shut down AD, I cannot login with a message 'CRS application server may be office. Please verify your system is online and try again'
Question is why the agent able to successfully login even the AD password change. I restarted UCCX server and agent desktop but had same result. where caching the old credential?
Thanks in advance,
abdul ilyas Tue, 01/27/2009 - 09:30
Interesting, check what happens next after, if you try Perform Ldap full sync from CUCM6.
