01-23-2009 06:23 PM - edited 07-03-2021 05:03 PM
We're running the LWAPP with the WLC's model 2000 and AP's model
AIR-AP1242AG-A-K9. We assign static addresses to the WLC's, however DHCP addresses for
the AP's. We need to obtain the config from the AP, however were not able to ether telnet
or http/s into them. Is there a way for us to access an AIR-AP1242AG-A-K9 AP, so that we
can get its config?
Thanks..
01-24-2009 07:17 AM
The configuration comes from the WLC itself. You can click on th eWireless tab on the GUI and then click on the ap if you want to see how it is configured. If you console into the LAP you can run a show lwapp ip config to see its ip address. Here is a link just in case you need to reset the ap:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a00808e2d27.shtml
If you are running 4.1 or later, then you can run these commands in the cli:
config ap username
config ap ssh enable
or
config ap telnet enable
This will allow you to run commands as if you were consoled into the ap.
01-24-2009 12:11 PM
Thanks for your response. Both, the WLC & the LWAP are remote from us, so we can;t console into them. We can http/telnet into the WLC, but not LWAP. Is there a way to telnet into the LWAP?
Thanks gain..
01-24-2009 01:46 PM
The commands are in my original post. You have to telnet or ssh to the wlc and run those commands.
