Extension Mobility
Answered Question
Jan 23rd, 2009
Hi all,
I have a query about extension mobility. I am using CCM version 6.1.2.I want that the EM users should automatically logged out at 7 0'clock in the evening irrespective of any time they have logged in through EM.
Secondly, after 7 0' clock anybody wants to again login EM , he should be able to do so.
We have configured default time as 8 hours from the time they login.
regds,
aman
Correct Answer by Jaime Valencia about 8 years 1 month ago
sorry, that capability is not implemented
there are no timers to control that, the only one is the forced logout after X time
java
if this helps, please rate
Overall Rating: 3 (1 ratings)
Correct Answer
Jaime Valencia Fri, 01/23/2009 - 20:34
java
Anonymous (not verified) Fri, 02/06/2009 - 07:17
Look at the product from www.rsconnect.net they might be able to do something for you
