Jan 24th, 2009
Sorry if it is not the correct forum for my question. I have a Cisco 837 Router which i want to use for Internet at my home only. Is there any easy guide to set it up? I checked on the internet but could not find something good.
mangesh.kamble Sat, 01/24/2009 - 11:25
Please find the attached link for Cisco 837 Router.
The Cisco 837 ADSL Broadband Router has an integrated ADSL WAN port with a four-port 10/100 Ethernet LAN switch for connecting multiple PCs or network devices in a small-office network.
Hope it's the same with you. Anyways this will surely be helpful to you.
Hope to Help.
cscisco_admin Sat, 01/24/2009 - 14:31
Yes i have the same but the problem is that it is not dhcp enabled and i am unable to connect to it. Is there a way i can reset it to the factor defalut settings?
