cisco877W (ADSLoPOTS) connect to ADSLoISDN ?
Carsten Radke
Is there a way to connect the cisco 877W (ADSLoPOTS) to an external dsl-modem ?
I've changed my telephoneline from analo to isdn.
Any help ?
If you have PPPoE, you configure that on the port that has a different vlan assigned to it:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_example09186a0080094475.shtml
(note, you don;t need the vpdn group stuff in the example above).
But it is not said that you have PPPoE.
5 Replies 5
paolo bevilacqua
With an advanced services image, you should be able to create a vlan for the external modem.
If I understand right, I've to create a seperate VLAN to Fastethernet0, connect the DSL_Modem to Fastethernet0, make Fastethernet0 a member of my Diealergroup and thats it ?
Have you an example config for me ?
Carsten
I've tried your response, but the router doesn't connect to internet.
The debug shows:
internet#sh debug
Dial on demand:
Dial on demand events debugging is on
PPPoE:
PPPoE protocol events debugging is on
PPPoE data packets debugging is on
PPPoE control packets debugging is on
VPN:
VPDN events debugging is on
VPDN packet debugging is on
internet#
*Mar 1 01:21:34.751: padi timer expired
*Mar 1 01:21:34.751: Sending PADI: Interface = FastEthernet0
*Mar 1 01:21:34.751: pppoe_send_padi:
FF FF FF FF FF FF 00 24 14 43 6C 25 88 63 11 09
00 00 00 0C 01 01 00 00 01 03 00 04 83 BC 8E 08 ...
show vlan-switch:
VLAN Name Status Ports
1 default active Fa1, Fa2, Fa3
10 ethernet0-dsl active Fa0
My config:
dot11 syslog
dot11 ssid test
authentication open
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.10.2
ip dhcp pool sdm-pool
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.2
domain-name navi.de
dns-server 62.72.64.237 62.72.64.241
lease 0 2
ip domain name cradke.de
ip name-server 62.72.64.237
ip name-server 62.72.64.241
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
vpdn-group pppoex
! Default L2TP VPDN group
username xxx privilege 15 password 7 1xxx8307927
archive
log config
hidekeys
bridge irb
interface ATM0
description DSL-Internet
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
description to DSL-Modem
switchport access vlan 10
pppoe-client dial-pool-number 1
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
ssid test
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description
no ip address
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip tcp adjust-mss 1412
bridge-group 1
interface Dialer0
description xx
ip address negotiated
ip mtu 1492
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxx@versatel
ppp chap password 7 xxx7E72
ppp pap sent-username xxx@versatel password 7 xxxx117F7D
interface BVI1
description $ES_LAN$
ip address 192.168.10.2 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 100 interface Dialer0 overload
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.10.0 0.0.0.255
access-list 100 remark SDM_ACL Category=2
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 remark SDM_ACL Category=128
access-list 101 permit ip host 255.255.255.255 any
access-list 101 permit ip 127.0.0.0 0.255.255.255 any
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
please help,
Carsten
you do not need vpdn-group.
Put the pppoe client under interface vlan10.
