PIX 501 setting factory default
Jan 24th, 2009
What is the command for setting a PIX 501 to factory default settings, Version 6.2(2)?
The following command does not work.
pixfirewall(config)# configure factory-default 192.168.1.1 255.255.255.255
Specified IP address (192.168.1.1) is not allowed; it's a broadcast address.
JORGE RODRIGUEZ Sat, 01/24/2009 - 17:33
if you are using /24 network command syntax should be:
configure factory-default 192.168.1.1 255.255.255.0
or you can do configure factory-default command alone and it will use 192.168.1.1 255.255.255.0 for your inside interface and automatically create DHCPD pool for you on inside interface.
http://www.cisco.com/en/US/docs/security/pix/pix62/command/reference/c.html#wp1055799
saidfrh18 Sat, 01/24/2009 - 19:15
Jorge,
Neither command seem to work.
Cannot select private keyWarning: Start and End addresses overlap with broadcast
address.
outside interface address added to PAT pool
pixfirewall(config)# configure factory-default 192.168.1.1 255.255.255.0
Warning: Start and End addresses overlap with broadcast address.
JORGE RODRIGUEZ Sat, 01/24/2009 - 19:44
never seen that before, use a different network address for sake of erasing the config, try 172.16.1.1 255.255.255.0 if success then do it for 192.168.1.1 /24 if not joy you may need to do write erase .
I assume you are doing it from local console
let me know if it worked out
