static NAT with route-map
Jan 25th, 2009
Hi everyone,
i need to know if the following problem can be solved with an ISR x800 (adv sec image) and if it can, how.
The problem is: i have a single public ip and a server inside with a private ip.
I need to forward tcp (port 85) trafic coming from some public addresses to the internal server on port 86; and the rest of the internet coming on the same port (85) to the same internal server, but on other port (88).
I was thinking about someting like:
access-list extended ACL_1
permit ip the_public_ip_1 my_public_ip
permit ip the_public_ip_2 my_public_ip
route-map RMAP_1
match ip address ACL_1
access-list extended ACL_2
deny ip the_public_ip_1 my_public_ip
deny ip the_public_ip_2 my_public_ip
permit ip any any
route-map RMAP_2
match ip address ACL_2
ip nat inside source static tcp 192.168.0.10 86 2.2.2.2 85 route-map RMAP_1 reversible
ip nat inside source static tcp 192.168.0.10 88 2.2.2.2 85 route-map RMAP_2 reversible
But it does not work.
Any ideeas?
The reason for needing this is because i need to migrate from a linux to cisco and on the linux box it can be done.
Giuseppe Larosa Sun, 01/25/2009 - 03:10
Hello Costin,
I remember a similar thread of some mounths ago.
From the command reference of 12.4 the syntax of command ip nat inside source is described as follows:
ip nat inside source static {tcp | udp {local-ip local-port global-ip global-port | interface global-port}} [extendable | mapping-id map-id | no-alias | no-payload | redundancy group-name | route-map | reversible | vrf name] [match-in-vrf]
see
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_nat.html#wp1011696
in that case was the combination of static NAT on specific TCP ports that didn't work with a route-map.
A static NAT not port based was able to invoke and use a route-map instead a NAT port specific NAT not.
the command syntax says that some parameters are in or when you see "|"
So you may be facing a functional limitation of IOS.
Hope to help
Giuseppe
