why is traceroute so slow?
Answered Question
Over the years I have observed that the command
router#traceroute ip xxx.xxx.xxx.xxx
when used on 800, 1700 and 1800 series routers, returns route information extremely slowly. What normally takes second when executed on a host, takes virtually minutes on these routers.
Does anyone know why?
Correct Answer by Harold Ritter about 8 years 3 months ago
Louie,
This could be due to the fact that the traceroute will try to do a DNS reverse name lookup by default. This can add quite a bit to the traceroute, especially if you don't have a DNS server configured on the router. Try "no ip domain-lookup" in global configuration mode and retry the traceroute.
Overall Rating: 5 (4 ratings)
dhananjoy chowdhury Sun, 01/25/2009 - 02:27
  • Silver, 250 points or more
Probably because when you are doing trace from Cisco router its sending UDP packets for the trace.
But when doing a atraceroute from a host(windows pc etc.) its using ICMP.
Correct Answer
Harold Ritter Sun, 01/25/2009 - 08:28
  • Cisco Employee,
Louie,
kaustubhchavan Mon, 01/26/2009 - 22:29
This could be due to the fact that the traceroute will try to do a DNS reverse name lookup by default ?
What it means plz explain in brief
Harold Ritter Tue, 01/27/2009 - 07:29
  • Cisco Employee,
Kaustubh,
It means that this command will send a reverse DNS lookup request (IP address to host) to the DNS server. If "ip domain-lookup" is configured and "ip name-server" is not, the DNS request is sent to the broadcast ip address (255.255.255.255). This obviously cause some delay in the command, unless there is a DNS server directly connected to the router.
Harold Ritter Tue, 01/27/2009 - 07:38
  • Cisco Employee,
Just as a precision, if the reverse DNS lookup succeeds, you should get the hostname in the output of the traceroute as follow:
r1#trace 192.168.4.1
Tracing the route to 192.168.4.1
1 R2 (192.168.12.2) 20 msec 20 msec 52 msec
2 R3 (192.168.23.2) 20 msec 20 msec 20 msec
3 R4 (192.168.34.2) 32 msec * 28 msec
r1#
