Mutiple Fractions on PRI / MGCP
Jan 25th, 2009
Dear ALL ;
I am facing the following situation , your help is highly appreciated.
I want to get 2 PRI-Groups on the same PRI and use MGCP as CUCM will control it. The scenario is as following :
1st PRI-Group is for incoming calls ONLY from PSTN , it should use timeslots 1-11
2nd PRI-Group is for outgoing calls ONLY from PSTN, it should use timeslots 20-30
How is the possibility to implement that solution on CUCM 6.x.? I know that there is a possibility for only one PRI-group fraction-based feature using MGCP , and there is a solution using H323 ; but I want that kind of solution as CUCM will control some other FXOs/FXSs for the ease of use need.
Jaime Valencia Sun, 01/25/2009 - 10:05
  • Cisco Employee,
  • Hall of Fame,
    2011
as you already mention you can only control one group with MGCP so you'll have to use H323 for this purpose.
java
if this helps, please rate
