URL Services: And Enterprise parameter
Jan 25th, 2009
Hi sir,
My question if we define Extension mobility in using URL service option in enterprsie parameter globally. can we used another service (like paging )when i press services button ?
Bcoz i think if we define EM in Enterprise parameter we cannot use any other service bu pressing service button.Please need your suggestion , AM i right? only one service will be avalible at a time if we define in enterprise parameter.
Overall Rating: 3 (1 ratings)
Ayodeji oladipo... Sun, 01/25/2009 - 06:44
You do not define extension mobility under enterprise parameters. You can configure multiple services for phones to use. Services are configured under device >> Device settings>Phone Services..
After you have configured the serviceS you want, you will then subcribe the phones to that service.
HTH..Pls rate useful posts
