show interface transducer loss issue
drhodes
We have two 10GB links using the Cisco 10GB LR x2 gbics in a 8 port 10GE card (WS-X6708-10GE), one which is showing high optical loss, while the other is fine.
gw-01#show int transceiver
Transceiver monitoring is disabled for all interfaces.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Current Tx Power Rx Power
Port (Celsius) (Volts) (mA) (dBm) (dBm)
Te2/1 35.7 0.00 40.6 -1.4 -15.6 -
Te2/2 29.0 0.00 5.2 -2.6 -3.5
When we switch the links the loss doesn't follow the fibre, and swapping out the end gbics also does not resolve the issue. We are at a loss on how to resolve.
Has anyone else come across this?
David
its-networking
Hi David
Lee here looking for how to enable
"Transceiver monitoring is disabled for all interfaces"
On those 10 gig interfaces
Not much happening around here hey
Cheer's ...........Lee.H
