ASA 5505 Cannot send/receive email from inside vlan
Answered Question
Jan 25th, 2009
Hello all,
When I try to send or receive e-mail from inside vpn I get:
6 Jan 25 2009 07:54:16 106015 75.180.132.77 xx.yyy.121.101 Deny TCP (no connection) from 75.180.132.77/110 to xx.yyy.121.101/1805 flags RST ACK on interface outside.
xx.yyy.121.101 is my outside vlan.
75.180.132.77 is RoadRunner cable my isp provider.
E-Mail server is in the dmz vlan.
I can send receive from a pc on the internet......
Configuration follows:
ASA Version 7.2(4)
hostname ciscoasa
domain-name my.domain.com
enable password *** Removed Intentionally *** encrypted
passwd *** Removed Intentionally *** encrypted
names
interface Vlan1
nameif inside
security-level 100
ospf cost 10
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ospf cost 10
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
ip address 192.168.8.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
switchport access vlan 3
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
access-list outside_access_in extended permit tcp any host xx.yyy.121.101
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
global (dmz) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (dmz,outside) tcp interface www 192.168.8.2 www netmask 255.255.255.255
static (dmz,outside) tcp interface smtp 192.168.8.2 smtp netmask 255.255.255.255
static (dmz,outside) tcp interface pop3 192.168.8.2 pop3 netmask 255.255.255.255
static (dmz,inside) tcp interface 3389 xx.yyy.121.101 3389 netmask 255.255.255.2
55
static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 xx.yyy.112.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface outside
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:*** Removed Intentionally ***
: end
Correct Answer by Richard Burts about 8 years 5 months ago
Jose
If my analysis is correct then the host at xx.yyy.121.101 sent at request for POP3 (port 110) to 75.180.132.77. So my first question would be whether 75.180.132.77 is functioning as a POP3 server? If it is not, then that would certainly explain why it rejects the attempted connection.
Rick
Overall Rating: 5 (1 ratings)
Richard Burts Sun, 01/25/2009 - 17:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jose
I am a bit confused about your post and what the problem is. In some parts of the post you talk about internal vlan and in some parts you talk about internal vpn. I am not clear whether there is an internal vlan and an internal vpn or whether you are confusing terms.
I think that we can tell a little bit if we look carefully at the error message. The first thing that I notice is that a packet is denied because there is no connection and it appears to be a packet from outside to inside. But when we look further we see that the port associated with the source address is 110 (which is pop mail) and the port associated with the destination is 1805 (which is an ephemeral port usually associated with the client in a client/server communication). From this we can deduce that the client which got translated to the outside interface address attempted to initiate pop3 and that 75.180.132.77 rejected it. We know it was a rejection because the TCP flag in the packet was RST which is used when a host rejects a TCP connection.
Rick
vbdotnetman Mon, 01/26/2009 - 02:58
Sorry about that Rick...
It should read as:
When I try to send or receive e-mail from inside vlan I get:
How can I tell why 75.180.132.77 rejected it?
Jose
Correct Answer
Richard Burts Mon, 01/26/2009 - 04:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jose
Rick
vbdotnetman Mon, 01/26/2009 - 05:20
Hi Rick,
I really have no way of telling if it's a mail server unless I contact the ISP.
My guess is it must be a mail server... I'm using the same Outlook settings as
my laptop which connects fine from the internet.
Below are my outlook settings from my inside clients Outlook session:
Incomming Mail Server- Mail.systems-programmer.com) "This server resides in my DMZ vlan"
Outgoing Mail Server(SMTP)- smtp-server.sc.rr.com
When I send a test message from Outlook I get the following error messages returned:
"Log into incomming mail server(POP3): Outlook cannot connect to your incomming(POP3) E-Mail server.
"Send test E-Mail message: None of the authentication methods supported by this client are supported
by your server."
Based on this information I should at least be able to connect to my
Incomming mail server(mail.systems-programmer.com is pointed to by DynDns points to xx.yyy.121.101)
in the DMZ vlan.
I guess I don't understand why it's goint to port 110 at 75.180.132.77 and not port 110 at xx.yyy.121.101?
I hope all this makes sense?
Jose
vbdotnetman Mon, 01/26/2009 - 08:10
Rick,
I contacted my ISP provider and they said that port 110 was blocked. They suggested I wait for 24 hours for the unblocking to take effect.
As you can tell I'm not well versed in network issues and do appreciate your assistance.
I you lived near by, I'd buy you lunch... LOL :-)
Best Regards
Jose
PS. If it turns out this is not the problem I open another Conversation.
Once again thanks for your help.....
Richard Burts Mon, 01/26/2009 - 08:53
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jose
I am glad that you got your problem resolved and that my responses were helpful in that. Thank you for using the rating system to indicate that your problem was resolved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that responses received did lead to a resolution of the problem.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
vbdotnetman Mon, 01/26/2009 - 11:26
Hi Rick,
It turns out my port is not being blocked. I can telnet into it on port 110. The ISP technical support is of no use. They won't even look at it.
If I contact Cisco they want a service contract number which cost a few thousand.
I am so disappointed in Cisco. For the money I paid I would have liked some type of support?
Can you recoomend another router I can purchase that is reputable and is somewhat easier to configure that has simmilar functions. Anything but Cisco or Linksys.
Best Regards
Jose
