RME syslog automated action
Answered Question
Jan 25th, 2009
I d like to make syslog automated action when %RTD-1-ADDR_FLAP appears to syslog. I create and try to select it from list of syslogs. Any idea how to find from that list anything when defining new message type.There is quite hard to find anything from that list of syslogs.
Correct Answer by Joe Clarke about 8 years 3 months ago
This message is not in the pre-compiled list. The list cannot be complete as new messages and platforms are added all the time. That's why the interface allows you to specify your own message type. In this case, click the Add button (instead of Select), and specify the following values:
Facility : RTD
Sub-facility : *
Severity : 1
Mnemonic : ADDR_FLAP
Description : *
Overall Rating: 4 (1 ratings)
Correct Answer
Joe Clarke Sun, 01/25/2009 - 10:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Facility : RTD
Sub-facility : *
Severity : 1
Description : *
u346874_2 Sun, 01/25/2009 - 23:22
OK thanks. I did that. Is there a way to see or search from that list (select). It takes lot of time when try to search from that long list.
Juha
Joe Clarke Sun, 01/25/2009 - 23:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You cannot search. However, the list is indexed by facility in alphabetical order. So, in your case, you'd find the RTD facility, then expand it to see the various messages.
u346874_2 Sun, 01/25/2009 - 23:32
Looks like i need some updates because i cant see RTD facility.(Now using LMS2.6 RME 4.0.6)
Joe Clarke Sun, 01/25/2009 - 23:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Right, as I said before, your message is not there. There are many messages not in the built-in list. If you can't find the message you want, then you will need to add it. Personally, I find it quicker to always use the Add button.
