Easy VPN between 877 & 3845
Jan 25th, 2009
Dear All
I whould like to establish EASY VPN between 877 and 3845.
Following information
1. 3845 already i am using for DMVPN ,gi0/1 is given publich ip
2. I want to terminate same easy vpn on dmvpn router
I am getting following message on my easy vpn remote router
Feb 19 19:50:04.241: ISAKMP:(0): processing vendor id payload
*Feb 19 19:50:04.241: ISAKMP:(0): vendor ID is Unity
*Feb 19 19:50:04.241: ISAKMP:(0): processing vendor id payload
*Feb 19 19:50:04.241: ISAKMP:(0©o0):Checkingàlicy
*Feb 19 19:50:04.245: ISAKMP: encryption 3DES-CBC
*Feb 19 19:50:04.245: ISAKMP: hash SHA
*Feb 19 19:50:04.245: ISAKMP: default group 2
*Feb 19 19:50:04.245: ISAKMP: auth XAUTHInitPreShared
*Feb 19 19:50:04.245: ISAKMP: life type in seconds
*Feb 19 19:50:04.245: ISAKMP: life duration (VPI) of 0x0 0x20 0xC4 0x9B
*Feb 19 19:50:04.245: ISAKMP:(0):Encryption algorithm offered does not match policy!
*Feb 19 19:50:04.245: ISAKMP:(0):atts are not acceptable. Next payload is 0
*Feb 19 19:50:04.245: ISAKMP:(0):Checking ISAKMP transform 1 against priority 65516 policy
can u tell me wht is wrong with my config on both the router
i have did configuration using SDM and followed the document for easy vpn remote form cisco sites.....
ggilbert Mon, 01/26/2009 - 06:28
  • Cisco Employee,
Can you please send me the config of your 3845 router.
Gilbert
