2811 redundancy
Jan 25th, 2009
My current configuration has R1's s0 interface connection to a patch panel.
However, I would like to install a redundant 2811 (R2' s0)to the same patch panel. I'm not sure if it requires a second cable or a y-cable?
The configuration should still allow the standby router to see rip updates and user traffic.
help
paolo bevilacqua Sun, 01/25/2009 - 13:55
  • Hall of Fame,
    Founding Member
S0 ? to a patch panel ?
Which interface is that, check properly.
paolo bevilacqua Sun, 01/25/2009 - 15:35
  • Hall of Fame,
    Founding Member
Serial interface don't go to patch panels usually. You cannot do Y-cables with serial interfaces, and you will need a second link to feed a second router with.
