pgcristovam Sun, 01/25/2009 - 12:08
dial-peer voice x pots
destination-pattern 00T
port 0/0/0:0
prefix 0021
So when you dial 003456789 the voice gateway will send 00213456789.
Chris Deren Sun, 01/25/2009 - 13:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
The above example will only work for calls destined to POTS dial peers. For calls destined to IP desitnations translation rule is your best option.
Chris
sunnyverghese Mon, 01/26/2009 - 12:45
Hi Rob
i am fine how about you thank you for your reply actually i need to create a prefix 600
From Router A if a user dial 600 and 3 Digit extension number the 600 number needs to discard at router A and sent the calls to router B
Example: 600601 dial from A
the extension 600 need to discard and sent the 601 to router B. Is it possible through prefix dialing.
pgcristovam Mon, 01/26/2009 - 12:56
translation-rule 600
rule 1 /^600/ /601/
translation-profile CHANGE_NETPRO
translate called 600
dial-peer voice x voip
destination-pattern 600...
translation-profile outgoing CHANGE_NETPRO
session target ipv4:X.X.X.
