Cisco attendant console call control failed only with 7931
Answered Question
Jan 25th, 2009
I have CCM 6.1.2. I configured attendant console according to the instructions stated earlier in the forum.
Create AC user account
Create AC Pilot number
Give directory number
Set Partition
Set CSS (ensure CSS has access to all other device partitions)
Save and return to configure pilot group
Add hunt users
To add AC user lines select User Memeber in pop up window then use bottom two drop down boxes
Select save then close
To add futher users repeat last 3 steps
Save changes
Note that the pilot point is not registered yet
Create ac Application User account
DO NOT add any devices, pilot points or route points
Just create it and save it
Go to User Groups
Enter "standard cti" as the search criteria and click find
Add the ac application user account to the following user groups:
Standard CTI Enable, CTI Allow Call Monitoring, CTI Allow Call Park Monioting and CTI Allow Control of All Devices
Go to Cisco Unified Serviceablity
Go to Tools>Control Centre - Feature Services
Select server that Cisco CTIManager and Cisco CallManager Attendant Console Server are running on and restart the two services
If you go back to the pilot point it should now be registered
Install the Attendant Console software on the receptionists PC
Enter the CallManager's IP address the above services are running on and the DN number of the receptionists phone
Then enter the AC user account and password that you created at the start
As soon as call control has started, go online and all should be working.
I get an error only entering DN of 7931 phone. There is no problem using DN of 7911, 7921 phones and using the same attendant console user account. Is this a bug?
Correct Answer by Jaime Valencia about 8 years 5 months ago
Cisco Unified IP Phones that are used with the attendant console must meet the following guidelines:
•Use the attendant console with any Cisco Unified IP Phone 7905G, 7911G, 7912G, 7912G-A, 7940G, 7941G, 7941G-GE, 7960G, 7961G, 7961G-GE, 7970G and 7970G-GE that is using SCCP. You cannot use SIP phones as attendant phones, but attendants can receive and handle calls from SIP phones.
Cisco Unified Communications Manager Attendant Console
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fsccmac.html
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Sun, 01/25/2009 - 14:48
  • Cisco Employee,
  • Hall of Fame,
    2011
java
ajanik Thu, 02/12/2009 - 05:26
look at the Protocol Specific Information -> Outbound Call Rollover drop-down.
Switch it to "No Rollover".
