Call not completed
Jan 25th, 2009
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
My Customer is with following problem: In Site A He have the CCM version 4.1.2 and Site B He have the CCM version 3.1.3. There is a communication by trunk site A to Site B. When the call is originate A for B it's Ok, the call is completed normally. When the call is originate B for A the phone ring but there is not audio, after 8 seconds the call dropped. I already verifyed codec, link, route pattern, version of gateway, but, didn't found the problem. Any ideia or suggestion?
Thank You,
Wilson Santana
Overall Rating: 2 (1 ratings)
gogasca Sun, 01/25/2009 - 16:22
  • Green, 3000 points or more
Version 3.1 is pretty old.
Do you have ICT configured or just H.323 GWs?
If no audio and after 8 seconds call is dropped check Device Pool configuration for trunks is correct and that there is no firewall or security device between clusters
wilsonsant Mon, 01/26/2009 - 03:34
In this Topology we have ICT. We already check Device Pool and no found problem. The Customer informed that didn't change nothing securiting in the Cluster.
Wilson Santana
gogasca Mon, 01/26/2009 - 22:50
Ok i normally never trust customers ;) hehe but anyways please upload the detailed cucm trace for all servers in each cluster and let us know timestamps, calling called numbers and I can help u reading the trace.
