How to change the Directory Handler Greeting:
- Access the Unity WebSA and go to Directory Handler, you will see the Drop Down, Play and Record buttons.
- Select the Drop Down/Option and specify the extension from which you want to play or record and input the Unity IP address.
- If you click on the play button, Unity will call the specified extension and play the current greeting.
- If you click on the record button, Unity will call the specified extension and will start recording once you lift the handset.
